I'm at about 65lbs dry on a T1 with a PBS 230N. Smoke tank installed but no smoke pump/system. This turbine seemed to push Craig South's around quite well.
Be sure to get things as far forward in the airframe as you can during building. I'm balancing out pretty well but have my Rx batteries in the nose and ECU and light packs on the battery trays on each side of the NG.
Sorry ... no wet weight for me yet but you can estimate that from the dry weights.
JS
