Originally Posted by
dirtdart
Denny, when just get home I'll measure the ones on the plans. Thanks
Bill, see how that cowl has a wider opening. That gp cowl looks like the cowl on the radial rocket.
On a side note, of you do not have forstner bits, a 9mm casing with the edges sharpened will make a nice servo lead hole without fraying the wood. Also fit right into the chuck of the drill.
That is the cowl that was taken from my cowling that Jay put together and sent to Stan's about 10 years ago. It's our cowling. Order it and your cowl problem is over. You still have a hill to climb with the wheel pants. They are all too wide (side to side) you need to section 1/4 inch out and glass them back together.
Bill, Waco Brother #1
