RCU Forums - View Single Post - YS DZ70 or YS FZ80s Engine
Old 03-08-2017 | 04:07 PM
MrShoes
My Feedback: (15)
Originally Posted by airraptor
IMO I would get the 80FZ. It has the pressurized fuel system and easier to run. The DZ is strong but in the 70/80 size it is a little more finicky to tune. I will someday run a 70FZ on same prop and then a 80DZ and then a ignition on all of them. The 80 is hard to beat for the power it makes with a weight of around 18 ounces. You maybe able to run less oil but I wouldn't do it. The oil does add to the compression some. I have run up to 55% nitro in mine and run 60% in my 115WS engines.
Airraptor,
Thanks for doing that comparison. Great numbers for both engines. As for the 70FZ on the same prop, RCSportflyer did a review and got 9,600 rpm (10.1 lbs thrust) on the APC 14x7 with 30% using the stock muffler. I don't think the YS DZ80 exists, but it would be awesome if they offered it.
