Building First Gasser
I'm building my first gas plane it's a corsair with a DLE20RA. I am planning on using a single battery setup and had some questions.
I'm planning on using a Ignition battery eliminater by Down and locked and plug that into an open channel on my RX and the other end into the electronic ignition. I don't really know a whole lot about these but this IBE is also a kill switch as its controlled by one of the channels. I'm using a 5 cell 2500nimh battery powering the rx. I've been told to use separate batteries so if the engine dies I will still have servos. My question is, if my rx has power then my servos have power so why would I need a separate ignition battery? Will my setup work?
