Originally Posted by
Propworn
The Lazy Ace 80 inch and smaller versions the wing both top and bottom will work without the interplane struts. The struts are not necessary structurally. That being said the plane looks funny without them. Make your own out of nylon or even aluminum. Be creative.
Dubro has cowl mounts that look similar you might be able to modify them.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWDH1
Dennis
Thanks Dennis, I looked at the Dubro item but will keep looking. Maybe could use a small eye screw or make something from aluminum angle. Was really thinking there might be a commercial item available for builders.
