RCU Forums - View Single Post - Question for DMD/MF unit users?
Old 03-12-2017 | 04:59 AM
heavyaslead's Avatar
heavyaslead
Originally Posted by Ex_Pat_Tanker
I have an M18 that I'm trying to wring a little more speed out of... It's fitted with a Tamiya sherman DMD and MF currently. I know people that know people that have run them on 12v in 1/6 scale vehicles, but what I don't know is whether the extra voltage gets passed on to the things that the 1/6 scale guys might not have used - i.e. the flash, TBU and IR LED. Has anybody experimented with this successfully, or should I be nervous about things going pop?!?
(Secret option B might be to try El-Mod - I don't have a problem with blowing up a $15 HL flash unit in the name of science, a $50 Tamiya flash unit is a different proposition...)
Should probably add: I'm thinking of 7 cell 8.4V or 8 cell 9.6V NiMH packs, no more than that.
The Tamiya DMD has a voltage regulator built in so no increase in speed possible that way.
I regularly run some of my tanks with 8.4V batteries with no issues (the voltage regulator has a voltage range it can work with)
As previously said, use a gearbox ratio mod to get more speed.
