I have a problem with my DLE 20 and after searching and searching I can't seem to find the same one so here it is:
Mine won't idle low enough and I can't kill it with throttle trim.
I took it apart again and the butterfly is tight and the reeds and everything look fine. I did notice tho that the throttle arm hits the engine case when trying to close fully. It's not actually the arm its the machine screw part of the ball link that is in the throttle arm. However, it appears to still close all the way as is and the high idle/can't kill with trim is a new issue (same ball link).
I was thinking about just buying a new carb for 40 bucks but I figured I'd see what the experts have to say?
Thanks so much,
Aaron
