RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 03-12-2017 | 01:13 PM
  #6838
aaroncmh
Originally Posted by nmav8r
Double check the travel (throttle butter fly) using the servo. I had the same problem it was my linkage . With the cowling off bring it to idle using the servo then see if you can get the idle lower by closing the the throttle by hand. Might save 40 bucks
Thanks for the reply and I did try that. I can't kill the engine or get the idle low with just the arm and no servo.
