Originally Posted by
microdon2
I also had problems with the DLE20 throttle arm linkage hitting the crank case. I ended up using a z-bend in some 256 rod, and was able to bend it so that it would clear the crank case. Another option might be to use a different throttle arm (one that tightens from the side instead of the overhead screw). Another possibility is that the throttle plate is not exactly centered. This is common in these DLE's. Might just be off enough so that you can't see it. Try loosening the throttle plate screw and reseating the plate, then retighten. (this can happen with the choke plate, too.)
A high idle in general is another common problem with the DLE 20's (or used to be - I haven't bought a new one in a few years). If you richen the low end to get the idle down it bogs the engine down. Some have said that the fix it to buy an EI for a different model DLE, like for the DLE 55. Downside - that's $75. Or get a generic RCExel EI for $50. Another option - use your "throttle down" function, where you fly with a higher idle, but cut the idle down another 2-3% just before landing. This very-low idle might kill the engine in a minute, but it's just enough to land the plane and start taxiing, then you can flip the toggle switch back to higher idle in time to keep the engine running while it taxis back to you.
btw - you should also have a remote EI kill switch on all of your gassers, so you don't need to kill the engine with the throttle. And \ or use a choke servo. Many fields require a remote kill for gassers, for safety. With all of the vibration of a gas engine it's not unheard of to lose a throttle linkage in air, and flying around at 1/3 throttle for 25 mins waiting for the engine to die is not fun.
Thanks for the reply...I think I'll try re-centering the throttle plate. That's the only thing that seems like it would cause the high idle to happen out of nowhere.
For the record, this thing is almost 4 years old and ran perfectly until the high idle thing. I do have an opti kill plus a charge/on/off switch in the fuse. I can shut it off at any time via the ignition just saying the unable to shut it off with trim is new and part of the high idle.
And to the smart ass guy, you try landing with an idle high enough to move the plane thru grass when she's on the ground cuz I'm not going to...I can crash on my own not gonna risk it with an engine not running right.
