Originally Posted by
ktsai
It's a wooden 2 blade prop 24x12, max rpm 5600 on ground and 7100 in air. I also tried Menz 24x10 2 blade (6300 on ground and 8400 in air) , Xoar 22x14 2 blade ( 5700 on ground, 7600 in air)
good to know. I have a couple of different 24x12 brands on the way to try on the Saito 90. It would be interesting to see if the RPM increases between the unmodified 83 and the new 90 are barely noticeable or if the 90 is a LOT more than expected. Are the carbs between the two the same style and basically unchanged?
