Originally Posted by
Dave Wilshere
Sorry, badly punctuated! You want 230mm, so do you still think you need tail weight?
Normally with the CARF Pipe a little nose weight is needed.
Thanks Dave, yes, to get 230mm, I will definitely need some tail weight. I guess the Tam's pipe made a big difference. Are you measuring with a full UAT as well? Mine's empty at the moment so, filling it will add even more weight in front of the CG.
I had a Classic Flash with aTam's pipe and it required some nose weight, The UF must be very different.
Thanks for the feedback.
