RCU Forums - View Single Post - YS user seeking sympathetic ears :(
Old 03-16-2017 | 12:19 AM
drac1's Avatar
drac1
Originally Posted by bjr_93tz
It's a factory cdi, not a conversion.
I'm really tempted to go the glow plug route, however I've heard the horror stories of backfires and kickbacks and I'm very reluctant to tempt fate. I've replaced the sensor, module and plug with no change to the problem, even running it directly off a battery instead of through the regulator to isolate that.
If I had an old workhorse to mount this into I might not be so concerned but as it is my Oxai ship is getting pounded left and right at the moment. It's turned out to be a good thing it was one of their more "solid" airframes.
I would run it on a glow plug Brett. It will prove whether it is actually an ignition problem or not.
You will have to richen both needle and reg, but you are using a large tank so will be able to fly the whole pattern OK.
Not sure what stories you have heard, but shouldn't be any different from a normal glow engine. Using a delay on the glow driver is a good idea though.
