Originally Posted by
pbratten
Hi there, I just bought a taranis x9e and am very excited to start using its tremendous capacity, but have run into a bit of a snag right out of the gate and am hoping to get some help here.
I plugged in the radio to the wall using the provided charger and left it charging overnight. However, the battery charge light never stopped flashing, even after being charged all night. I verified that the battery is plugged in (it is). When I push the power button with the radio plugged in or not plugged in, nothing happens. I am trying to figure out if something is defective (charger, battery, or something else) of if I am doing something wrong. Thanks in advance for any help that you can offer.
If the light is flashing it is not charging. It should flash less then a few min and then go solid green. When the light goes out it is fully charged. You are sure the battery is plugged in correctly? Do you have a volt meter that you could use to see if the battery has voltage?
Mike
