RCU Forums - View Single Post - Analog servos on Non essential
Old 03-18-2017 | 06:44 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by Jetpilot24
I do know that if you use the 22 ms on the TX then you do have to use digital servos. If you activate the Xplus the TX will automatically switch back to the 11ms. With that said that tells me that as long as I am on the 11 ms frame rate then analog can be used.
Thanks Joe
Actually you have that backwards. Analog servos operate at 50Hz / 20ms so 22ms frame rate should be Ok for any servo. Digital servos are capable of operating at a higher frame rate such as 100Hz or even higher so 11ms should only be used with digital servos.
