So i need some help from you experienced UF builds. I have succesfully installed the turbine and carbon covers, but i'm struggling to fit the inlet jointer for the bypass. The manual calls for trimming the back section, in the manual it looks like a half circle cut out....Not sure why they did it that way.
The manual also calls for trimming the side, however I decided to flatten out the entire section and added some hysol for extra protection.
What is the process you guys follow to install the inlet jointer? Installed the turbine and carbon cover and then the inlet jointer OR install the inlet jointer, then the bottom carbon cover, Turbine and then close off with the top cover?
As you can see in the picture, it seems as if the carbon bottom cover is not low enough restricting the connection to the inlet jointer.
