These tanks are made in Russia all Mark does is add the electrics, first thing you want to do is install the correct split link in the chain from the motor to the drive shafts at the moment you have a mild steel nut and bolt which doesn’t quite fit and will break with use when you rotate the chain you will notice that it has a large slack spot this is down to the mild steel nut and bolt.
