Originally Posted by
FenderBean
Gun sorry see that beauty go in, I read your post and didn't want to bother you if your not in the mood. I was confused and wanted to make sure since eventually I do want to build one of these. This issue was the turbine being so close causing the turbines to read opposite rpm? I learned something here I didn't even know that was possible, but it makes since. Again sorry for the loss.
I also was unaware if this with twins. They need to be reclocked to avoid each other. Just can't clock them to much because then they won't start. Jim tried to break up the signal on his with carbon fiber between them and other stuff also. Nothing worked reliable accept reclocking them.
