I finally found some time to work on my engine starting station. First I want to show off my modified water hose reel. The store bought model did not last long before it started leaking. It seems most reels leak. I started this project 1 ½ years ago. I really need this utility reel now so I got back on the project by assembling my components. I had gutted the original set up and made a new feed tube and swivel out of PVC. Pressure tested to 75 PSI. Hope to give it an operational test soon. Not good looking; just a farm utility reel.
A couple of pictures on my new engine starting station. My old station was the bare minimum. I had no space for the starter, starter battery nor especially the transmitter. This new station will allow for all that plus a decent work area if needed. I still need to add the legs and wing trap. It will be a bit heavier but manageable. All my planes will fit plus there is room for larger planes. I'll post a final picture when completed.
