Originally Posted by
Captcrunch44
You had it out at sig but I don't think you flew it. Kind of a bummer. Wish I could give you a hand. But it's hard to do when i can't see or hear it run. Hope you figure it out the 120 is a great flyer
You're right I did have it out, forgot about that, I couldn't get it to run right then either. It might have a dirty carb. Maybe I will take it off when I get a spot cleared up in the shop and pull the carb.
Today I did some work on the Cub that I started making into a Biper Cub and failed to get the balance correct. The lower wings need rebuilding, but the rest of the plane had little damage. Waiting on the resin to cure where I repaired the cowl so I can sand and repaint it. Then I can balance it as a regular Cub. Only difference is the struts are not under the fuse, but mid fuse, and the lower wing attachment is still exposed. Haven't decided if I want to make new scale struts and cover up the attachments, or fly it as is and repair the lower wings and try again.
