RCU Forums - View Single Post - Clark Board Help?
Old 03-20-2017 | 07:29 AM
Rustytrax
It isn't hard to setup. You just need help.
Just to be clear the only real issue is the gun accidentally firing? You can adjust the limits of you TX with your PC ( if you have the cable). This will help with the gun firing.
The ability to change the stick functions is a limitation of the board since those functions are tired to that channel.
