Originally Posted by
Rustytrax
It isn't hard to setup. You just need help.
Just to be clear the only real issue is the gun accidentally firing? You can adjust the limits of you TX with your PC ( if you have the cable). This will help with the gun firing.
The ability to change the stick functions is a limitation of the board since those functions are tired to that channel.
Yes: when I try to elevate or lower my gun it fires (not all of the time) and it is very frustrating. The fire feature works fine but it fires on the left and right 3/4 setting more often then not. The lights are a pain to try to turn on but I can live without them.
Skip
