RCU Forums - View Single Post - Clark Board Help?
Old 03-20-2017 | 08:46 AM
Shorty54
Originally Posted by skip2a
Here is where my lack of knowledge is going to hurt.
Does the cable go to my transmitter or my board? I followed the link to Digital Radio but I have no idea what I am looking at. Is there a video out there somewhere that will explain all of this to me? Can I make the changes on my current radio or do I need a new one?
Sorry folks I am trying to be user friendly but I do not understand a lot of this. I am finally comfortable with changing batteries without worrying about breaking something.
Skip
The cable plugs into your PC and radio. The cable will have free software when you install it. The Digital Radio software is $2 i think. Once you have the cable hooked up to your radio you can then change all your parameters. You can change channels, for instance if you want the left stick to drive the tank instead of the right stick you can change it. If you want the main gun to fire on the down instead of up you can change it. Its also where you can mix channels and set your endpoints like Rustytrax explained. Its a learning curve but doable. Once done you can safe your settings. You can always come back and change things, if you mess it up, just go back to a previous version you saved. You can save several TK radios on there so if you get more tanks you can use the same software. You could have 1 radio and several tanks. Then you just in the radio to the PC and download your save setting for whatever tank you want to run. Much simpler than explained, lol. I am sure others can explain it easier than I can.
