Originally Posted by
TheBennyB
If your going the route of leaving steering non-centering you can just remove the lever and spring from the side to side axis and move it to the up/down gimbal I would think. Then you don't have to take much apart, just swapping.
Yes! That also works. A little more work, but you can remove the centering device on the left stick and copy it to a piece of styrene, get a small spring from the hardware store and make one. More work though.
