Originally Posted by
wblombard
Hi Paul,
I saw that video, yes that looks like a normal and easy landing model. Maybe the guy's UF from this weekend was not setup correctly OR just came in too fast.
What setup are you running and are you using crow... (I dont want to go into a debate on this crow thing, seems this is a hot topic)
Are you running the bypass? Man I cant get mine to fit. space is a major problem. Hopefully it will be ok to run without it.
You should not be having that much trouble fitting the bypass. It was a tight fit on both UF I've built but not bad enough that I considered leaving it off. Can you post a photo showing where the interference is?
