Originally Posted by
Bobneal1
A steel or iron plate will attenuate the magnetic cross talk between the motors.There is also something called miracle metal that is supposed to block magnetic fields. The thickness is the issue depending on how strong the magnetic field is. It could get heavy. I am building a Mig 29 with 2 Cheetah 160's and they are about 9" apart center to center. Just curious how far apart are the engines in the F-18?
They where about 1 inch apart in the front
