Originally Posted by
EDFJim
SAFTEY ALERT Any twin turbine setup check to see that one engine does not read the others RPM ... I had this problem with mine and spotted it while doing repairs. Another plane was lost at the event and we think this may have caused the problem. I was able to fix mine by rotating engine #1 45 deg.
Is your F-14 setup like Kris did his or as bidrseed has his setup if I might ask?
I've not flown my F-14 or even started the beast up with it's new engines, but mine are setup on a switch as bidrseed talked about and I'll watch for the RPM bleed over issue in any case.
