are you sure it's not setup for elevon (elevon active?) really weird having aileron and elevator connected or are all the outputs linked to the same input in the BETA programmer.. totally agree I was ready to give up myself but muddled my way to a solution . I have demon cortex gyros / E3 gyros / and this one is no worse to set up if you had instructions. I finally understand what I need to know to get my job done and it's actually very easy , but that is of little use to someone like you using the srxl..problem is who in the world knows how to use these things ??and why does spectrum not release some proper software and a programmer that is not full of bugs .I like in the beta programmer where it says after making adjustment click accept ??? no such button ?? what I have found is I need to unplug the receiver and plug the power back in and then the program prompts you to accept the changes . it's crazy
