Guys, while securing my 4mm polyutherine fuel lines inside the engine cover by twisting thin wire I found the wire breaks easily at the twist. I tried 4 different ones, the worse was the brittle from the wire bush as a tester. Any suggestions what type of wire would be the best for this procedure, .5mm gauge.
