Originally Posted by
littlera
Grant, the simple answer about the negative incidence for the horizontal stab is that this is the angle found to be correct for working with the wing at its angle of attack. I can tell you that this negative incidence is scale. The real C 120/140 has the exact same. There is a drawing floating around the internet that shows the incidence angles.
Thanks... We kind of figured that was the case.. What have you found to be the flight characteristics to be?
