Originally Posted by
bjr_93tz
I've tried screwdrivers, plastic cable ties, profanity and whatever else I can think of, but in that other recent thread that mentioned the crank installing tool YS now offer,(
http://www.yspower.co.jp/en/engine/acce.html ) Scott mumbled something about a 2 thou feeler gauge and a couple of screwdrivers and I gave that a go and it worked a treat. My rear bearing isn't exactly a press fit into the crankcase but it's tight enough.
The cam gear bearing is the bugger, the one in the cap comes out just fine with heat and a quick tap, but I always find myself bending up different shape pieces of wire and other oddments to get the crankcase one out. I've vowed to make up a tool but I'm just to lazy.
I just replaced the cam bearings with the ones I had in stock, and you can change them without pulling the head (or throttle) off. I just slid the tappets off their pivots, pushed up the lifters, pulled the cam gear, removed the lifters, pulled the bearing and put it back together in reverse order.
I did put a timing mark on the prop driver first though!!
I had a devil of a time getting the shaft back in with that blasted crank ring!!
I simply could not do it so I made a tool from a piece of brass toilet tubing that works but it is still difficult.....it looks something like the YS tool.
Also....I made a simple tool to remove the inside cam bearing...I'll get a pix of both for you tomorrow.
