RCU Forums - View Single Post - Band Saw Blade Recommendation and Setup
Old 04-01-2017 | 12:37 AM
CK1's Avatar
CK1
My Feedback: (60)
The OP's post was about the best blade for bandsaw use . Without debating over which is a better method of cutting , table saw ,scroll saw, etc , I will simply anwer his question.The smoothest cuts I have been able to make with a bandsaw have been from using a "Resaw " type blade . Low vibration means smoother cuts .
The resaw blade is designed to make smooth cuts.
http://www.highlandwoodworking.com/w...aw-blades.aspx
