RCU Forums - View Single Post - Balsa USA Smoothie XL Build
Thread
04-02-2017, 06:06 PM
61
pappy35
Covering is coming along nicely. I was going to use Solartex and paint in a WWI-ish theme but I've got my sights on a large IMAC plane next and since I'm fussy about covering on a plane like that I figured I'd use the Smoothie to brush up on my long dusty Monokote skills.
Pics 1 and 2: In order to start covering one needs to clean-up. These are before and after shots of the workbench. The fuselage is sanded down to 600-grit. After sanding I very carefully remove sawdust by first vacuuming and then going over the whole structure with a shop rag lightly soaked in mineral spirits. The bench was also very carefully cleaned.
Pic 3, 4, and 5: Color samples and checking basic patterns. Using a set of French curves I cut templates out of poster board for each of the colors. For me, curved patterns are visually appealing but can be difficult to do so working slow is key.
Pic 6: Ceremonial first piece of Monokote. I always start in a location that's not visible. Haha.
Pic 7: Strips of Monokote are applied at all the corners.
Pics 8 and 9: Did the first two of three colors on the vertical tail. The final piece will be a black swoop that wraps around the lower rudder corner. So far so good.
05:41 AM
Reply
Like
pappy35
View Public Profile
Send a private message to pappy35
Find More Posts by pappy35
View iTrader Profile
