I have used Testor's styrene cement in the black bottle with needle applicator for years, never a problem. For ABS, if it's for instance a wheel hub I use Moment rubber cement. If it's to be permanent I use gel type ACC, the gel type gives you a second or two to make sure the part is positioned correctly.
