If it's a large piece like the red, I will remove the underlying covering. For the gray swoosh I marked the boundary of the piece and use a woodpecker (with only two wheels installed due to the width) to prep the surface. You have to use a fresh blade for these cuts because you want to minimize the depth of the cut so as not to slice through the balsa sheeting. After I lay each piece down I'll wipe the area clean with Monokote trim solvent (nasty smelling stuff but it works great) to clean off the ink and seal the edges.
