Originally Posted by
bjr_93tz
I'm happy to say that after nearly two years (on and off) of pulling my hair out, the engine is finally back to it former self and running as it should. The final piece in the puzzle (lack of midrange) was that even though it was running well, the regulator was still too lean.
I picked up a bottle of coolpower MV purple oil and have run through about four litres of 30% nitro 15% oil. Whatever is going on compression and ignition wise at the moment, you can richen up the regulator and needle with impunity and it's burning it without question, billowing out smoke galore and hauling that plane around the sky like it's attached to a huge bungie cord. The tuning range on the main needle is quiet broad now.
I can't say the engine picked up any significant RPM on the purple oil compared to the blue. Once everything beds in I'll probably drop the oil back to 10% although I don't mind the oil on the bottom of the plane.
Just for comparison I run an APC 18.5x12WPN cut back to 18".
on 20% nitro 10% coolpower blue ~7,250rpm
on 30% nitro 15% coolpower blue ~7,650rpm
on 30% nitro 15% coolpower purple ~7,650rpm
The extra 400rpm on the 30% fuel is very noticeable, and so is the increase in fuel consumption.
Finally back to practicing flying again, rather than practicing take-offs and landings. Thanks to all the posters for their advice and support.
Glad to hear it's all sorted. Time to practise.
I used to run the 19 x11 on my 170cdi with 30 nitro. It flew really well with that prop.
The cdi's have huge mid range torque, so you don't need to rev them hard. I aim for around 7k, but 7200 or less is good. My 185's do around 6900.
Lower revs keep the noise down as well. My Xareltoo was noise tested at the Australian Masters/World Cup Event last month. It is 88db and my Valiant is 87db. The first time I have had my planes checked, so was extremely happy with that. The contras were around 90db and one only just passed the 94db limit.
I used a full 4 litre bottle on Sunday, which is 16 flights and didn't wipe underneath until packing up. There was just a smear of oil, one swipe and it was gone. 10% oil.
