Trainer function 7CH
I was trying to use the Trainer function today to give my grandchildren a bit of flying experience. I know it works as we have used it before, but i must have altered something as I couldn't get it working.
I went to the Trainer menu and changed INH to OFF. I thought that when you activate the function (by pulling on the spring loaded switch H) the OFF would turn into ON and the slave tranny would take over. Neither happened and I tried all the other switches in case I had somehow re-assigned the function. I also checked Para in case switch H had been re-assigned.
I don't remember fiddling with any of the various setting/ mixes/etc for that model channel as it is reserved for the electric Wot4 I use with them. But it is some time since I last used that model and age is taking its toll on my memory.
Any suggestions please
