The OP's post was about the best blade for bandsaw use . Without debating over which is a better method of cutting , table saw ,scroll saw, etc , I will simply anwer his question.The smoothest cuts I have been able to make with a bandsaw have been from using a "Resaw " type blade . Low vibration means smoother cuts .
The resaw blade is designed to make smooth cuts.
www.highlandwoodworking.com/woodslicer-resaw-bandsaw-blades.aspx
Please see post #3, the OP brought up scroll saws.
