RCU Forums - View Single Post - YS user seeking sympathetic ears :(
Old 04-10-2017 | 05:37 PM
  #111
drac1's Avatar
drac1
Originally Posted by bjr_93tz
That's the plan now Scott.
That valve clearance issue has been a bogey man hiding in the background for a long time now, which for the most part has been masked by oil content, needle and regulator settings. There's still something not right with my engine that requires I run it at the looser side of specifications, but I'm going to leave sleeping dogs lie for a while and might replace the cam at the next overhaul as it's about the only bit that's still original apart from the crank.
I'll probably drop back to 10% MV oil soon, but I'll put up a few more flights with the 19x11 before I change anything. It's still bedding in a new ring and I don't want too many things changing at the same time.
Sounds good.
Frazer Briggs was running the 19 x 11 on his 170 at the Trans Tasman in NZed last weekend and if flew the plane really well.
