I cannot definitively answer your question, but as a Lil' Swamp Buggy owner, I believe that most people flip the engine pylon around and run it in a standard tractor setup. Plus from what I have read, the engine gets better cooling as well from running in a standard configuration. As for the last question and being relatively new to airboats, if balanced properly, you should have no problems with flipping. There is someone that frequents this forum that will probably chime in here and offer better advice as he is the 'master' around here. He has many builds and is both very knowledgeable and helpful.
