RCU Forums - View Single Post - Some one know the - Fun Tiger Extra
Old 10-27-2003 | 04:03 PM
hilleyja
Default RE: Some one know the - Fun Tiger Extra
A very inexpensive 1st profile with all of the ills the previous poster expounded on.
Get the ARC version -- usually about $10.00 cheaper.
This will give you the opportunity to strengthen the glueing of the tail surfaces and give you a custom covering scheme. Definetely add a whole lot of glue to the servo mounts in the wing. I went one step further and litterally painted the cavity with epoxy and did the same with the opposite site of the ribs the servo rails are connected to -- no problems, my last flight was a dumb thumb and the only damage was a cracked fuselage, which I will fix one of these days.
Yes, it is heavy but will go ballistic with an OS FX .46. IMHO, a bearing .46 is the minimum engine for this airframe. It will do it all and not create a bottomless hole in your pocketbook.
