Originally Posted by
TSHARK203
Levi are you flying just elevons or elevator and ailerons? Or did you do a mix of both. I have functional ailerons on mine. I was told to mix the ailerons and still set up the tail group as elevons. Still could use a xicoy setting on the cg if anyone has usef the xicoy to set theirs up.
TSHARK I've also got functional ailerons and I only use aileron for roll and elevator for pitch. I could use a little more roll authority so a slight taileron mix with ailerons could work well. It's hard with the small ailerons to get enough roll and still set differential.
