RCU Forums - View Single Post - Composite ARF Mig29
Old 04-11-2017 | 09:11 PM
  #376
Levi Wags's Avatar
Levi Wags
Originally Posted by TSHARK203
Ok how much throw do you have on your surfaces? Once i get the nose gear fixed i can balance the plane and possibly get it in the air. I dont want it going in the ground on the first flight if i can help it.
As much as you can get on aileron and rudder, I think about 70 mil on elevator but I'll confirm for you.
My Migs nose gear collapsed twice during taxi tests filling the cockpit with hydraulic oil, took a lot of work to get it right. On the Mig 29 as you know there is so much weight on the nose gear as its right back under the cockpit. I also cut the springs in the mains to lower the rear height as it had a negative A of A. This also relieves the nose of a little weight too and helps with rotation.
