It depends how well your plane is balanced, If your tail heavy, you can still fly,but your nose will be very unstable to any input. Also Maybe,when you mounted your motor, you where not centered on your Datum line on the firewall. Also, your plans might have called for a few degrees of Pan up,down,right or left. Hope this helped a bit
