RCU Forums - View Single Post - Composite ARF Mig29
Old 04-13-2017 | 01:28 PM
  #386
Levi Wags's Avatar
Levi Wags
Originally Posted by gustavo Campana
I solve the problem to mount main paralel legs. There are one possibility.
You has to start mounting a piano wire inside the axle hole on mains gears, cross both mains, after that's mount the legs on the main landing fuse mount, mounting the system to the fuselage with epoxy, the epoxy will absorve the difference between the fuse mount and the correct position.... Sorry my English. The point is.... Fuse main plywood mount are not correct....
Gus the problem with mine wasn't the angle of the plywood as I could fix this by spacing out the mounts with washers to adjust the angle.
The problem was the arc that the leg swings on during retraction won't clear the fuse if vertical. Have you fixed yours yet and do you have a pic of what you've done?
Thanks Gus
Levi
