Originally Posted by
f3a05
The spin 99 usually has a small dead band at the very bottom of its travel,which may or may not bother you----one of my pattern friends prefers the OS ESC for that reason.
The only issue with using something different than a Jeti with a 28 pole Hacker, is that they don't work. So if you're running a 28 pole Hacker, stay away from OS and Castle ESC's.
