I did calibrate sticks with dipswitch 8 in the order you suggested, tried swapping servo cables, and tried left stick in every direction for some kind of response with no luck. I am not hearing the one second burst of elevation noise when powering the tank on from either board or sd card. The only sound I get is a very light static sound from speaker when turning power on.
