RCU Forums - View Single Post - On board Propain
Old 04-18-2017 | 09:23 AM
ravill's Avatar
ravill
I am still running 2 propane start jets and I love them.
I'm curious as you say our Merlin runs great and it is propane start. How did you start it before?
Here is how I use my propane start.
I have an onboard propane tank. It came with my engine.
I have a one way 4 mm festo with a "tee" in-between the tank and the propane solenoid. The 4 mm fuel line needs to be reduced to 3mm as that is size of the festo connector on the engine.
That's it.
I get my propane from REI or any camping store that sells it. It is a propane/butane mix usually. Like this:
https://www.amazon.com/Coleman-Butan.../dp/B000PY9T0S
I use the trigger valve to attach to the above propane/butane to connect to the one way 4mm festo. Like this trigger valve:
https://www.rcgroups.com/forums/show...ve-for-propane
