This line of engines has a troubling past. The primary issues we found were the pistons were undersized for the cylinder bore which caused premature wear due to piston slap (rocking in the bore) and no piston ring would solve that issue.
A properly sized piston to the bore would solve that particular issue.
I would make sure your bases are covered, clean carb, proper timing, reeds, etc.
