RCU Forums - View Single Post - Stuffing Box
Thread: Stuffing Box
Old 04-20-2017 | 01:23 PM
mfr02
Waterproof grease inside the tube. When installing the shaft, there should be minimal end play. At the prop end, between the locknut and the outer bearing, there should be at least a thrust washer, preferably two washers with an "O" ring between them, all with grease applied.
