Originally Posted by
crapshooter
does BIKERBOB mean the stuffing tube box [ not the actual tube that holds the shaft ] normally the stuffing box is fitted firstly into the hull then the stuffing tube slides into the stuffing box, this is where water can get into the hull between the 2 tubes.
The item I am concerned about is the tube that the shaft passes thru (it appears this is called the stuffing tube)
